Question JBL Control 1 for Yamaha YHT1810
Discussion in 'Home Cinema Speakers' started by krel, May 28, 2017.
  1. krel
    krel
    May 22, 2008
    Hey I've been fancying upgrading the speakers I got with my Yamaha YHT1810 home cinema kit, I'm on a low budget and was thinking of buying 4 JBL Control one for the satellites would they work ok ? I'm not very clued up technical side of AV
  2. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,265
    +1,885
    No reason why not, but you could probably do better. The Control 1 is a commercial speaker, so you are paying for a more robust case and some protection circuitry and also the mounting points whrn fixing to walls etc. As a design, it's also more than 20 years old.
    For the same sort of money, you could get 2 pairs of these: Q ACOUSTICS 2020IGraphite Speakers Per Pair which will sound significantly better, with more low end and cleaner highs.
  3. krel
    krel
    May 22, 2008
    Believe it or not that's exactly the set of speakers I opted for when i got to the shop ! Going back tomorrow for the centre speaker, very happy with these two, next payday I will add two more for the rear two
