Java
Discussion in 'Desktop & Laptop Computers Forum' started by highyellow1, Dec 18, 2002.
  1. highyellow1
    highyellow1
    I keep getting this error java.lang.ClassNotFoundException:wakeApplet.class"
    when trying to load a Java page, does anyone know how I can fix it? I loaded the JVM upgrade and tryed to disable Sun's Java plug-in but can't find it!
  2. graham.myers
    graham.myers
    Not a 100% sure but it sounds like your CLASSPATH doesn't contain the directory where the class file is.
    You can have multiple class paths - just seperatethem by a colon :))
