JASE, switched mains block...
Discussion in 'AV Receivers & Amplifiers' started by Lowrider, May 15, 2002.
  1. Lowrider
    Lowrider
    Jase,
    I have an Audio Design unswitched mains block, + another switched, (bought from an appliance store), to plug my gear without remote, two powers and a tunner.
    Now, the switch is not very good, so it "sparks" when I switch it on, and blasts my circuit breaker about 25% of the times...
    I tried to find an audio grade one, (4 plugs will do), on the net, but only came up with US and UK sites, different plugs than we have... :(
    Do you know any european site that carries this kind of stuff... :confused:
  2. Jase
    Jase
    Mar 16, 2001
    9,404
    South Coast
    +856
    Hi Antonio
    The only one I know of that has the european plugs and sockets is made by www.russandrews.com
    They have their Yello block available with 4 or 6 sockets and also their Power Block (Expensive!!!). They will ship to Europe as well.
    Also came across this site
    www.audiophilecandy.com which has some good stuff.
    Not bought anything from either company myself though, yet!!
    Jase
  3. Lowrider
    Lowrider
    Gracias,
    I will try them, I did find others that would ship to Portugal, but still with US or UK plugs, I will let you know...
  4. Jase
    Jase
    Mar 16, 2001
    9,404
    South Coast
    +856
    Antonio
    :eek: I think its only the Power Block, expensive one, that comes with euro sockets.
    I remember now, I was going to buy the Yello block but would have had to change all my plugs to UK plugs.
  5. Lowrider
    Lowrider
    I could get another Audio Design with euro sockets here, but they don´t have a switch, and I don´t want to leave the amps on all the time, nor have to switch off and on both, plus the tunner, everytime...
    Maybe I will have no choice... :(
