hi
i have a japanese wii with a wiikey thats was installed about 2 yrs ago (if thats relevant). just wondered if theres any way of changing the menu languages to english?!
Yes you can, but all the letter r's will be changed to l's and vice versa.
A bit niggling but it is playable like that.
no kidding - had a Japanese origin software at work and it said "Crick here!"
hi
You can completely change the region/language etc but it's a bit more work than just changing a setting.
You need to run a region changer program via homebrew.
Bit of a pain but this results in a 100% Pal UK machine
i havent got homebrew and it sounds complicated to get it. i have a wiikey so does homebrew really matter for me?!
Yes and no - if you are happy with a NTSC Wii that's text is in Chringrish then no.
If you wan't you console to work like a proper PAL UK machine then yes.
Regards
i dont really mind, i dont know to what extent we are allowed talk about it, but i just want to play all region roms! language is just a preference!![]()
