January Software Upgrade Problems (iPod Touch)!
Discussion in 'Headphones, Earphones & Portable Music' started by Vipers, Jan 16, 2008.
Tags:
  1. Vipers
    Vipers
    Oct 16, 2005
    4,099
    Stevenage
    +650
    Just bought the January Software Upgrade to add the new apps to my Ipod touch, followed the instructions, updated to firmware 1.1.3 and synced my ipod, the apps are then supposed to be available but nothing has appeared, has anyone else bought the apps, did they work?
  2. martin@wolfy
    [email protected]
    Apr 30, 2002
    242
    +13
    go to the device in iTunes and click on the 'check for updates' button. will then download the 165mb of 1.1.3 update and when applied it should recognize you have paid for the apps. I did the same as you and followed the instructions which did not work
    wolfy
  3. Vipers
    Vipers
    Oct 16, 2005
    4,099
    Stevenage
    +650
    I've already updated to 1.1.3, when I check for updates now it says I have the current version. I've googled the problem and other people are having the same problem when manage music and videos is ticked, they are having to restore their Ipod then the apps appear, trouble is they loose everything on their Ipod, there has to be another way.
  4. robzter
    robzter
    Aug 25, 2005
    468
    Fulham
    +6
    im having the same problems.ive updated everything i should have and its not showing.
  5. elektrobix
    elektrobix
    Dec 17, 2007
    69
    11
    +14
    Quite a few people have had problems apparently such as being charged several times. I think if you do everything in the right order it's fine (I think)? I did mine by:
    1) Updated iTunes to latest version, then
    2) Updated Touch software to latest version, then
    3) Bought the upgrade, then
    4) Clicked on the iPod in iTunes and clicked 'Synch' - the new apps appeared next time i used it.
    My iPod is not on manual mode but i know some people who do have it on manual mode and the update worked fine so i dunno :rolleyes:
  6. saleshark
    saleshark
    Oct 25, 2006
    97
    I have manual checked and mine worked with the procedure above
  7. Vipers
    Vipers
    Oct 16, 2005
    4,099
    Stevenage
    +650
    I got an e-mail back from Apple Last night and I had to uncheck manually manage music and video in the summary tab and then synch, it meant I lost all my songs and Video on the touch but at least the apps work now, bit of a crap way around it really, time to put all my music back on :thumbsdow
    Heres the link Apple sent me about installing the software updates :-
    http://docs.info.apple.com/article.html?artnum=307243
  8. Kwozzii
    Kwozzii
    Jun 29, 2003
    295
    Northants
    +16
    I have been charged twice for the software - if I do this procedure on the other halfs touch will it still install, I really don't fancy paying for it again...
    Cheers,
    Kwozzii
  9. Chrispyphillips
    Chrispyphillips
    Jan 7, 2007
    2,185
    63
    Finally, Chrispyphillips HAS COME BACK, To Swansss
    +227
    How come we have to pay for this anyway?! I've never paid for an ipod update before! Have I missed something?!
    Is there a chance this will become free before long, or is there even a need to get it?! Will the ipod still work fine without it!? I cant believe we're being charged! :eek:
  10. Kwman
    Kwman
    Sep 7, 2004
    2,612
    London
    +995
    Just paid, DLed and installed onto my touch. Working fine, but its wrong that they are charging £12.99 for it.
    I used quidco so maybe I can get the 8% discount !
  11. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    I have all the ticks for synchronization and it worked perfectly for me in dummy proof mode.
    I went to their webpage and selected purchased
    Complained about the latest iTunes version - Upgraded
    Complained about the latest firmeware - upgraded
    Purchased - unplugged and plugged and synced
    Everything worked fine
    Set up POP client and weather location: no probs
    Played around with Google maps: No problem
    I'm happy :clap:
