ToTTenTranz
Greetings,
Me and my girlfriend are setting up a new Home Cinema + Music Listening + Gaming set in a mid-small sized room.
First and foremost, we've pretty much decided on the Pioneer VSX-921 (the one with the EISA award) because of the price/performance and features/performance ratio (both of us have Android smartphones to control the receiver, for example).
While looking at our locally available options and our budget, we've come down to two choices:
- The Jamo S606 HCS3 5.0 set (two full-range towers but no active subwoofer)
- A Wharfedale Crystal CR30 setup (CR30 Centre + 2*CR30.2 + 2*CR30.4) + a System Fidelity SW250 active subwoofer.
We both prefer the Jamo's looks, so we're more inclined to the Jamo set, but I'd like to know if the lack of an active, dedicated subwoofer will make a large difference. We're not going to set the sound levels very high, as we probably won't ever pass ~50% of the output from the receiver.
If we get the Jamo set, we also don't put away the idea of getting a dedicated sub later (in half a year or so), but our current budget doesn't take more than this.
Also, in both cases the bookshelf speakers will be in the front, next to the TV (where we have a bookshelf..) and the tower speakers will stay in the rear, behind the couch. Is this "horribly bad" by any way?
I'd also like to know if the MCACC will automatically set the low frequencies to come out from the Jamo's tower speakers when a 5.1 source is applied through the HDMI/Optical (for example, a set-top box), or if I'll have to somehow set it manually.
Thanks for the advices.
