Jamo Pj Hcs-3500?
Discussion in 'Home Cinema Buying & Building' started by mi11er, Sep 21, 2004.
  1. mi11er
    mi11er
    Can't find any reviews or even full specs of this animal JAMO PJ HCS-3500?!
    CD/CD-R/RW/VCD/SVCD/DVD/DVD-R/RW
    -DIVX
    -DOLBY DIGITAL/DOLBY SURROUND PRO LOGIC DTS
    -MP3 / MP4 / PICTURE CD
    ...and ~350 euros in local store.
    Any opinions?
  2. electron
    electron
    A great receiver I must say. It will play any dics to put in. Here is a little help to you. I found the specifications in the manual:
    TECHNICAL SPECIFICATIONS
    Power supply: 230V 50 Hz AC
    Power consumption of DVD receiver: 88 W
    In standby: < 2 W
    Video signal standards: PAL, NTSC
    Readable discs: 8cm, 12cm
    Impedance of front speakers: 8 ohms
    Impedance of centre speaker: 8 ohms
    Impedance of surround speakers: 8 ohms
    Impedance of subwoofer: 6 ohms
    Peak music power output 2000 watts (PMPO)
    Specifications subject to change without notice.
    Found it at their website: www.pj-sound.com
    Also here is another thing I found out:
    How to change region code and check software version:
    when DVD tray is open
    <Software version> =>Hold VOLUME_UP_KEY and then press ZOOM_KEY, it will display software version on OSD;
    <Tuner>=>Hold VOLUME_UP_KEY and then press SUBTITLE_KEY, it will display TUNER region on OSD, if change tuner region, press DOWN_KEY, and then press ENTER_KEY to confirm;
    <Region code>=>Hold VOLUME_UP_KEY and then press AUDIO_KEY, it will display TUNER region on OSD, if change region code press DOWN_KEY, and press ENTER_KEY to confirm;
