Jamo JSS4-VC2 Speaker Selector
Discussion in 'Hi-Fi Stereo Systems & Separates' started by DPool, Jan 20, 2008.
  1. DPool
    DPool
    All,
    I just purchased this speaker selector and I cannot figure out how I am supposed to connect the amps and speakers to it. It seems I may be missing a few wiring harnesses.
    Below is a picture, there are 8 pins per 'connection area' and there are three seperate areas, 1 for the 2 amps, 1 for speakers 1 and 2, and 1 area for speakers 3 and 4.
    [​IMG]
    Any help or ideas are MUCH appreciated.
    TIA,
    Doug
  2. pacheko
    pacheko
    Jul 1, 2008
    HI:
    THERE IS NO PROBLEM, THIS CONNECTORS ARE SUPOUSED TO BE USED TO CONNECT TWO DIFFERENT APLIFIERS TO YOUR JAMO SPEAKER SELECTOR SO YOU CAN SEND TWO DIFFERENT SIGNALS TO YOUR SPEAKERS.
    IN THE FRONT PANEL OF THE SPEAKER SELECTOR THERE ARE A SMALL BUTTONS THAT ALLOW YOU TO SELECT WICH AMPLIFIER IS ACTIVE (A OR B).
    BUT YOU CAN CONNECT ONLY ONE AMPLIFIER (A OR B) TO WORK WITH YOUR SPEAKERS.
    HOPE I HELPED YOU OUT.
    :hiya:
