Jamo DVR50
Discussion in 'Home Cinema Buying & Building' started by dannybrown, Aug 23, 2005.
  1. dannybrown
    dannybrown
    does anyone know how to factory reset a Jamo Dvr50 system? somehow i've lost picture but still have sound, as the hidden features are controlled on screen i can't see them to change them. Would be grateful of any suggestions.
    Cheers Danny
  2. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    hi danny
    i seem to remember early on my dvr50 froze up and went all a little weird i was advised to download the current firmware from the website and install and ive been trouble free since touch wood.
    i do remember tho that their technical dept ( number on website) were very helpful and got me up an running very quickly if you havent already contacted them just give em a call.
    Hope this helps
    cheers
  3. dannybrown
    dannybrown
    thanks, am waiting for a reply from the distribution centre in the UK which is where i gather they offer tech support from, i have also downloaded the firmware upgrade but can't load it as have no screen to access the menu, thanks for your help anyway, i will persue the tech support people.
  4. pannymad
    pannymad
    May 14, 2004
    11
    maybe its because you have set component output - I thought I read somewhere that if you set this then you can't see the menus?
