jamo dvr50 rce modification
Discussion in 'Blu-ray & DVD Players & Recorders' started by bba1, Aug 31, 2004.
  1. bba1
    bba1
    does anyone know of where i can modify a jamo dvr50 to play rce discs. thankyou.
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    If you have made it multiregion then if you open the tray and do info 2 7 6 and you can specifically chose region 1. They should then play. A pain but it does work!
  3. bba1
    bba1
    thanks everso much. i'll try it.
