jamo dvr50 problem
Discussion in 'Home Cinema Buying & Building' started by Bigmonty69, Jan 12, 2004.
  1. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    826
    +73
    I just bought a Jamo DVR50 with 305 speaker package.
    Everything is connected and works ok, even the multiregion menu setting to all.
    However I have a problem on some DVDs in the fact that the menu and the main feature picture appears to jump every 0-15 seconds or so.
    Is this a common problem with some people?
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    When you say jump do you mean like lose sync. I.e the picture goes up or down and then goes back to the middle. If so it could be your tv doesn't quite like the signal from your jamo. You could try another connection type to see if thats any different. Assuming your currently using scart rgb you could try s-video or composite instead. You could also make sure the scart leads are properly secure as some sync problems are simply because the scart plugs aren't fully inserted.
