Jamo DVR50/PDD305
Discussion in 'Home Cinema Buying & Building' started by plane_co, Oct 24, 2004.
  1. plane_co
    plane_co
    Sep 18, 2004
    25
    4
    Hello
    The set up:
    Toshiba 40" Rear Projection TV
    Sky+ Digibox
    Jamo DVR50
    Connections:
    The Jamo has component, S-Video,digital optical in and out and an array of phone sockets.
    The TV has three Scart sockets, S-Video, Digital optical out and phono sockets.
    The Sky+ has two Scart, S-Video, Digital optical out and phono sockets.
    First question, the best way to connect everything up?
    For ease of use I have used Scart for all connections as follows:
    Sky+ box vcr socket to Jamo
    Sky+ box tv socker to Toshiba
    The second question is that I have noticed a tinny sound to the speakers when I am using the TV or Video mode through the Jamo system. It's at higher volumes and it sounds like an electical cracking. Difficult to desribe the sound really. The thing is I don't believe it is the speakers, because I don't get the same problem when playing DVD's.
    Has anyone had this problem with the Jamo system?
    Can anyone suggest anything which may overcome this?
    The Scart leads I am using are the standard ones which came with the Jamo and an old VCR, so are not very good quality.
    Any help would be much appreciated. :lease:
  2. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Hi there
    i have much the same system altho have a component enabled plasma Tv
    connections ive used are as follows:
    jamo to screen component link
    sky+ to screen rgb scart
    sky+ to jamo optical link
    all cables are good quality QED leads and have no problems with either
    picture or sound
    i cant comment on your speakers as i went for the 325's from jamo and to be frank the sound is awesome
    dvd quality pics are noticably better than the sky+ pics but thats to be expected
    my advice invest in some decent cables as this does make a difference(dont go way overboard) normally theones supplied are inferior
    hope this helps
    cheers
    kevin
  3. plane_co
    plane_co
    Sep 18, 2004
    25
    4
    Hi KevH
    Thank you for your reply.
    I have tinkered with the connections and am now using the Digital Optical instead of Scart for Sky+ to Jamo and it has cured to sound problems.
    So I now have Scart for Jamo and Sky+ to TV and Digital Optical for Sky+ to Jamo.
    Now I have a solution to the sound problem, I'll invest in some better cables.
    Can't thank you enough, this has been driving me nuts.
    :D
