Jamo DVR50 package. A305 v A325
Discussion in 'Home Cinema Buying & Building' started by Boaky, May 18, 2004.
  1. Boaky
    Boaky
    To cut a long story short, I've settled on one of these systems as my first entry into the Home Cinema world.
    Question - is the A325 speaker pakage worth the extra £150 over the A305
    I don't need a beast of system - room is approx. 20 - 25 sqm - and I'll probably use the system for music as well as DVD's if that makes a difference.
    Any advice gratefully received.
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    ive read some where the sound quality is no different but for the extra £150 you dont get the big box sub which is huge !
    you may want to check out the 3 other speaker packages that are 210PDD, A355, A410PDD. i like the A355 with the front floor standing speakers but that would be preference on your part.
    have a look here http://www.av-sales.com/html/home_theatre_kits.html
