Jamo DVR50 or Panasonic HT900
Discussion in 'Home Cinema Buying & Building' started by honeydew, Nov 14, 2003.
  1. honeydew
    honeydew
    Nov 10, 2003
    131
    19
    Man I cant decide...all reviews I have seen say more or less they are the same.
    As far as I can see the Jamo has the following advantages:
    DivX/Xvid playback
    PAL progressive scan
    Panny has:
    Floor speakers so you dont have to shell out a further £80 a pair on Jamo stands.
    Help which one...the wife is no help at all - 'whatever you like dear' arrrghhhhh
    Thanks, rekall
  2. daviedee
    daviedee
    ive just got the panny scht900, lovely looking system but wot u got to bear in mind is the size of it D400 L430 h60 all mm. so if u have a small stand then its going to hang off it.
    also are you going to use the divx feature? i download a lot of movies of imesh and most are avi so u will need to convert them to divx, is it worth the hassel??? the jamo is nice looking but the stands dont look to stable for when kids are about.
  3. honeydew
    honeydew
    Nov 10, 2003
    131
    19
    i thought most if not all films in divx/xvid mode are AVI format anyway...
  4. daviedee
    daviedee
