Jamo DVR50 HACK
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mikeaitch, Nov 4, 2003.
  1. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Does anybody know how to hack this to multiregion?
    Apparently Unbeatable are sending out instructions with theirs?
  2. Stinja
    Stinja
    Aug 13, 2003
    12,486
    163
    +3,953
    I got mine from Unbeatable, but didnt notice any instructions. Upon loading a region 1 DVD i got a message saying "invalid region" and the DVR50 spat it back out.
    But i'll take a look through all the boxing now to see if it was tucked away somewhere, and i missed it in my frenzy to setup... otherwise i'll call Unbeatable, and ask directly and post back here.
  3. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Thanks Ized looking fwd to that :smashin:
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Have you tried either the Momitsu v-880 hack or that for the Bravo D1? Both are the same chipset and might use similar firmware? (sorry haven't got the hacks to hand..)
    Ian Guinan
  5. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Try this..............Press load (disc tray opens), press "info", press "2, 7, 6, select region then press "load" to exit.
    I hope that's right :)
    Sigs
  6. Paul D
    Paul D
    Dec 27, 2000
    2,737
    Manchester
    +534
    There is a new firmware update on the Jamo website.
    www.jamo.co.uk
    Doesn't make it multi-region, but does enable extra playback of Divx files and some search modes etc.
    Just burn the file to CD-R and then insert in your machine.;)
  7. Paul D
    Paul D
    Dec 27, 2000
    2,737
    Manchester
    +534
    There is a option in the hidden menu which states:-
    SCART: Y Pb Pr:
    480p
    576p
    720p
    It's the 720p bit i'm interested in!
    Tried setting it to 720p, but my plasma still states 625p is being received.
    I also tried it via the scart output, using a scart to component (3 RGB phonos etc)
    The picture is visable, but it's like having double vision!
    Any ideas?:suicide:
  8. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Thanks for all the replies!!
    Only one problem- the dvr 50 won't recognise dvds any more:eek:
    I'm going to get it changed, then try again
  9. ching
    ching
    I've being trying the hack for the Jamo DVR 50, namely:
    load, info, 2, 7, 6, region code, load
    but without any success. I get a menu displayed after pressing 6, but there's no option to select the region code. I've tried just pressing 1 for region one, after the 6 and before the last load, but no joy. Does anybody know what I'm doing wrong? The firmware version is 2.7.6.
    Thanks.
  10. Rampage
    Rampage
    Dec 17, 2003
    290
    +7
    Same problem here, I think the 2.7.6 firmware doesn't support multi-region!
  11. Jay23Sx
    Jay23Sx
    Theres loads of threads about this on here, basically you need a special version of the latest firmware for the multi-region hack to work .. if you look on here you'll find people offering it ..
    However, if you got it from unbeatable and dont fancy taking a risk speak to them and they'll send out two pre-tested CDs to you which'll do the job ..
  12. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    We have the multiregion upgrade file available at work. If you PM me with your e-mail address I can arrange to send it to you.
  13. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    FIRMWARE UPGRADES TO JAMO DVR-50 REMOVES MULTI-REGION PATCH.
    That is all.
  14. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,018
    U.K.
    +628
    here's the full hack(s) and reasons for them:
    go to www.drg4.fsnet.co.uk
    now click on the 'links' button on the left hand menu.
    now scroll down the page with yellow background that loads on the right.
    now click on my (new) DVD Page.
    At the bottom of this page is the hacks needed and full instructions.
    PS not sure if it's macrovision disabled as well though :)
    PPS firmware upgrades DON'T remove the multiregion capability as long as the firmwares you upgrade to are multiregion ready.
    That is all :devil:
