JAMO DVD-593 Multi-Region Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Ozzie Bob, Jul 6, 2005.
  1. Ozzie Bob
    Ozzie Bob
    Here are the instruction I received from the Australian JAMO distributor to make my DVD-593 Region FREE. After doing the following procedure, I can now view R1 and R4 discs I previously could not :smashin:
    1. Turn machine ON
    2. Press MENU
    3. Press DOWN ARROW once
    4. Press 0 (number Zero) 0 = Multi-Region
    5. Press MUTE
    6. Press PREVIOUS (Chapter/Track)
    7. Press NEXT (Chapter/Track)
    8. Press OK
    After this, your machine MAY turn ON the Parental Lock. If it does, do the following:
    1. Press MENU
    2. Press DOWN ARROW - Scroll down until you get to the 'key' symbol
    3. Press RIGHT ARROW - To get across to 'parental'
    4. Press RIGHT ARROW - Gets you to 'enter code'
    5. Press 1 2 3 4
    6. Press DOWN ARROW - Scroll down until you get to 'no parental'
    7. Press OK
    8. Press MENU - To get you back to start - You are now finished
  2. vrajendra
    vrajendra
    Is the JAMO 593 DVD Player RCE proof meaning will it play RCE/REA (region code enhanced) DVD discs? If not is there a way to make it RCE proof
  3. lemke
    lemke
    Looks great
    I've got to test it.
    Maybe another question for the Jamo fans.
    In the beginning, srt-subtitels worked fine, but it isn't anymore.
    The srt-files work fine on my PC. Any idea ?
    Lem
  4. vrajendra
    vrajendra
    I tried the hack steps listed and it worked. If is ptu the DVD player in standby mode the DVD player is set back to it's original area code, I mean I have to redo the steps to set it to region 0. Can somebody please help.
    Thanks,
    Rajendra
