Jamo Concert Centre / D8CEN - anyone own/owned/heard one of these?
Discussion in 'Home Cinema Speakers' started by dave48, May 6, 2002.
  1. dave48
    dave48
    Mar 9, 2002
    275
    Germany
    +4
    This post slightly overlaps with another thread I have running at the moment, but before I make an expensive (or maybe not so expensive) mistake ....
    Has anyone got a Jamo Concert Centre (or D8CEN as they now seem to be called)? I have Jamo Concert 8's as my front speakers and need a centre speaker. The advice I'm getting is to go for a Mission 77c1 - but I just want to double-check that the Jamo Concert Centre is not in fact the greatest speaker since sliced bread etc. etc. and I'll regret it for the next 100 films if I don't get one of those ....
    Thanks for your thoughts,
    Dave48
    P.S. it would be driven by a Denon 3802.
  2. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    I will keep it simple. :)
    The Concert Centre is an excellent centre speaker.
    I own one, and absolutely love it's totally natural and clean/smooth sound.
    Get a demo if possible and see what i mean.
    Do a search on it, as this speaker has come up a few times in past threads.
  3. dave48
    dave48
    Mar 9, 2002
    275
    Germany
    +4
    Getting a demo is one of the major probs I have - there is no dealer near here who sells the thing, I'd have to order it over the Internet (same is true of the Mission speaker as well though).
    The concerns I have are:
    - is the Denon 3802 up to driving it ok (I believe it is a 4 ohm speaker and the manual goes on about not using less than 6 ohms, I think)
    - it may be a bit big to balance on top of the tele (no projectors for me unfortunately)
    - it is 3 times the price of a Mission 77c1
    But it would match the Concert 8's nicely ....
    Dave48
  4. dave48
    dave48
    Mar 9, 2002
    275
    Germany
    +4
    Just checked the stats and indeed the Denon says 6 ohms + whereas the Jamo is 4 ohms. Is this a problem in practice? Don't want to blow up my shiny new amp :)
    Dave48
  5. Big Jim
    Big Jim
    not a problem in practice, no.
    the 3801/2 is a fairly powerful amp, so you should have no problems unless you are using it extreemly high levels
