Jamo 305 AV Subwoofer question: The light on the front
Discussion in 'Home Cinema Speakers' started by G-man.au, Apr 7, 2005.
  1. G-man.au
    G-man.au
    I have just setup a Jamo 305 AV speaker package at home and I notice that there is a small LED on the front of the sub that never turns on. I checked the small manual that came with the kit and it doesn't mention the LED.
    Sub seems to be working correctly.
    Should this light be on when the sub is on or is it a warning light when something goes wrong?
  2. Rampage
    Rampage
    Dec 17, 2003
    290
    +7
    The only time you'll hear that light mentioned on these forums is because people are complaining that it is too bright!
    It should be on all the time that the sub is on, it's a bright blue colour.
  3. Rampage
    Rampage
    Dec 17, 2003
    290
    +7
    Did you buy it new?
  4. docb
    docb
    Nov 22, 2004
    253
    I have the same speakers and the bl**dy thing is on continuously. Far too bright.
    If the sub is working correctly be thankful it is not on.
    Doc
