Jamo 2.1 s vsr 25 fault
Discussion in 'Home Cinema Buying & Building' started by panasonicman666, Feb 7, 2009.
  1. panasonicman666
    panasonicman666
    Jan 5, 2008
    176
    Hi All
    I have the above jamo, it is a great machine but the fm aerial has broken, i have had it fixed but the guy said it may need a new block inside. The FM connection is a whole unit, does anyone know where i can get one from as i want to replace the whole fm tranciever.
    I hope this makes sence?
    Mike
  2. panasonicman666
    panasonicman666
    Jan 5, 2008
    176
    Anyone??
    Thank you
    Mike
