Jag
Discussion in 'TV Show Forum' started by paul0703, Nov 4, 2004.
  1. paul0703
    paul0703
    Hi Im new to this forum, but can anyone tell me or point me in the right direction to find out when FX289 will be showing the remaining seasons of JAG, I watched evryone upto season 5 and waited with bated breath for season 6 but then they showed season 1 again.
    Any help greatly received
    thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There is only a simple email contact on the website.
    It's not unusual for a channel to buy a set amount of seasons and repeat them a few times either to guage viewer interest or spread out the cost of purchasing a full series over a few years.
    However it may be that a few seasons may have their PAY rights tied up either by SKY1 or Hallmark.
  3. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    "JAG" Season 6 will probably be on Hallmark or FX289 again, very soon.
    If you want to keep up with American shows, and which channel is showing what episodes and/or when a particular series is being aired, I'd highly recommend that you download the trial version of a brilliant piece of TV guide listings software called "DigiGuide".
    Click here and see if you think it will do the job for you. I'd highly recommend it, as it has a lot of personalisation that you can do.
    Pooch
