Jade Empire help (spoilers)
Discussion in 'Xbox Forums' started by R^T, Mar 19, 2006.
  1. R^T
    R^T
    I need help.
    I have just killed Gaos father and landed in the new dragonfly and now I think I have to get to the dam.
    Where is the dam I can't find it anywhere.
  2. RockStrongo
    RockStrongo
    Jan 11, 2005
    874
    28
    Newcastle
    +53
    Difficult to describe exactly where you have to go. Check the map and make sure that you've been through every exit point in each area. You'll soon find you way to Tien's Landing.
    This bit of the game is a bit of a slog, but it is worth ploughing through as it gets much better not too much later on.
    If all else fails try www.gamefaqs.com and navigate to the Jade Empire walkthroughs.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    Here's the direct link to the walkthrough.
