Answered Jabra Solemate: Fixing female micro USB output inside the speaker
Discussion in 'Headphones, Earphones & Portable Music' started by JabraKick, Feb 15, 2016.
  1. JabraKick
    JabraKick
    Feb 15, 2016
    3
    Internet
    Hi, I'd like to ask you for your help.
    Intro
    I have a problem with "usb micro-b female" inside speaker Jabra Solemate.
    I think it's disconnected from the motherboard, but you can read whole story below.
    This is everything I have in the package, with my Jabra: Image of the Package
    (usb charger, wall charger, 3.5 mm audio cable)
    Description
    As I was listening to the music (speaker connected to the laptop via usb cable), while having my laptop on the wall shelf, accidentally the speaker fell down (to the kitchen board).
    Now, there was some "crack sound" and once I pulled out the usb cable, I could hear
    that (probably as I'm not any audio technician) usb micro-b female part was removed from the motherboard. You can always hear something is inside the speaker while shaking with it.
    Problem
    I can't charge the speaker. There are two options how to do it: connect via usb - micro usb to the laptop or connect via micro usb to the wall (electricity).
    Listening to music is possible via 3.5 audio cable or bluetooth.
    Questions
    Is it possible to fix, "glue back" the usb micro-b female part to the motherboard?
    Is the any other way to charge the speaker?
    (I suppose charging via 3.5 audio jack is still impossible in this world)
    Whoever could help me anyhow, I'll be very very thankful.
    Thanks for reading!
  2. Best Answer:
    Post #4 by JayCee, Feb 15, 2016 (1 points)
  3. JayCee
    JayCee
    Jan 20, 2004
    23,207
    Lanarkshire
    +2,484
    Electrical/electronic connections need solder, not glue.
  4. JabraKick
    JabraKick
    Feb 15, 2016
    3
    Internet
    You need to learn meaning of quotes. Please, only helpful answers.
  5. JayCee
    JayCee
    Jan 20, 2004
    23,207
    Lanarkshire
    +2,484
    Best Answer
    And you need to learn manners.
    Once more, glue alone cannot be used to fix the socket, it requires soldering and a high degree of dexterity and precision to reattach it to the printed circuit board.
  6. JabraKick
    JabraKick
    Feb 15, 2016
    3
    Internet
    Thank you, sir.
