iyama ProLite B2409HDS-1 - Is it any good?
Discussion in 'Computer Peripherals & Consumables' started by decmatt, Feb 12, 2009.
  1. decmatt
    decmatt
    Dec 16, 2004
    15
    Iiyama PLB2409HDS-B
    I am looking at the monitor above, is it any good for primerly PS3 use, or would you recommend anything above it (this is really my max price). Also would Logitech X-140s work ok?
  2. robtek70
    robtek70
    Oct 15, 2006
    241
    +19
    I don't know about this particular monitor but I have recently purchased the Iiyama ProLite B2407HDS which I use on my PC. I have connected my PS3 and HD media streamer to it and the quality of the video is very good. Only problem I found was that the sound quality from the monitor wasn't all that good and really needs to be connected to an amp.
  3. crossbow
    crossbow
    Nov 18, 2007
    1,832
    83
    S Oxfordshire
    +257
    I would get the E2407HDS & save ~£30-35 from Insight - using a 10% voucher code (see HUKD forums for this). It has an Audio IN port - not sure if this will be suitable for speakers though.
    The main difference between these two models seems to be that the dearer one has a better stand with height-adjustability, pivot, etc (& a few other 'gimmicks'). If you ever need these capabilities in the future, you could get a very good Ergotron Neo-Flex stand for £25 off Scan (the stand gets good reviews btw).
