IXUS 400 - cannot turn on
Discussion in 'Photography Forums' started by Eakley, Aug 2, 2004.
  1. Eakley
    Eakley
    Was using my IXUS 400 fine yesterday, but today it won't turn on. I've recharged the battery and it is showing green in the charger, but the camera completely fails to respond to anything.
    Any suggestions anyone. It is 3 weeks out of warranty! :mad:
  2. HMHB
    HMHB
    Nov 11, 2001
    26,941
    Nottinghamshire
    +5,779
    Make sure that the battery door is firmly closed and that the CF door is closed properly too. Do you get anything happening at all when you try and switch on ?
  3. Eakley
    Eakley
    Nah, nothing at all. Have reseated both doors, and have even pushed the microswitches in to try and check to see if there is something wrong with the door catches, to no avail.
