iXtreme gold 2106 and SKY
Discussion in 'Microsoft Windows' started by daveser, Aug 30, 2005.
  1. daveser
    daveser
    having had great fun installing my new iXtreme gold and MCE I have hit a problem - I cannot get it to recognise SKY - I have tried RF out using coax into my tv card, also tried scart to red/white/yellow all to no avail
    I have read the related forums and can't find the answer - any ideas out there ?
  2. spikerules
    spikerules
    have you tried s-video?
  3. daveser
    daveser
    unfortunately no s-video connection on my SKY box..
  4. DaveP
    DaveP
    Presumably you have the correct lead? These cables are directional. Some come with a switch to enable you to select the direction.
    You need a scart to AV cable. If you are not even getting any sound then it looks to me like you have an AV to scart!
    Dave
  5. daveser
    daveser
    thanks Dave, the direction is good because I can plug it into a thompson wireless transmitter and gives a perfect signal - is there anything that needs to be checked in MCE to say recieve signal from satellite box ?
  6. DaveP
    DaveP
    Yes, when you run TV setup for the first time you have to tell it to use a sat receiver. You also tell it, IIRC, how it is connected (component or s-video)
  7. daveser
    daveser
    ok, thanks for the help, i will run TV setup again and see what happens !
  8. nigelbb
    nigelbb
    Apr 4, 2005
    5,268
    103
    +490
    From a quick Google on iXtreme gold it appears that you are referring to a Packard Bell system with a digital DVB-T (Freeview) tuner. This is not suitable for connecting an external set top box like Sky+. You need an analogue TV capture card such as Hauppauge PVR150.
  9. daveser
    daveser
    i can only get a signal using scart to s-video - for some reason using the rf-out on my sky box and a coax connection does not enable me to pick anything up
    and with s-video the picture is black and white
  10. daveser
    daveser
    all sorted - required some tuning and refit of the card - thanks for all your help
