IXOS XHT611-075 Flat Scart Lead
Discussion in 'Cables & Switches' started by Jedwards, Sep 19, 2005.
  1. Jedwards
    Jedwards
    Jan 31, 2005
    44
    I've been recommended the IXOS XHT611-075 Flat Profile Scart to Scart Leads to hook up my Philips 36PW9252 TV, to my Sky box. Can anyone tell me whether these are the best ones to buy, or would they recommend any others within a similar price range?
    Many thanks!
    James
  2. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    5,985
    2
    2
    Bromsgrove
    +584
    It's a good lead and relatively inexpensive.
    It depends on how much you want to spend and whether or not you can tell the difference between that and a more expensive/different cable.
    The QED P2110 is supposed to be excellent also:
    http://cgi.ebay.co.uk/QED-SQART-P21...19399QQcategoryZ15067QQtcZphotoQQcmdZViewItem
    Or a better IXOS one i've used and had excellent results with - the XHT801:
    http://cgi.ebay.co.uk/IXOS-XHT801-S...19297QQcategoryZ15067QQtcZphotoQQcmdZViewItem
    Not sure on your budget though....
