IXOS PS2 lead not working with PE5120 !
Discussion in 'Projectors, Screens & Video Processors' started by seb4213, May 31, 2005.
  1. seb4213
    seb4213
    May 15, 2005
    25
    3
    I've just brought my first component lead and I cant get it to work on my projector!
    I've connected the correct colours to the others (althought the colours on the lead and the PJ arent in order with each other!) and I cant get a picture,
    Should I ring the place I got it from or Benq?
    or am I missing something :rolleyes:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Presumably you've switched input on the projector to component?
    Have you ever had the PJ working with any other device?
    Have you tried outputting simple composite (ie single yellow) to the PJ to see if that works? Just as a test, not with the intention of sticking to it!
    ...PJ :)
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Asides from possibly not having a working cable, or indeed a working projector. I'm sure you have to rig up the PS2 to your existing telly, go onto the setup menu and change the output to YPbPr (or YCbCr can't remember which) from RGB. Then stick in your component lead and run up to the projector.
  4. seb4213
    seb4213
    May 15, 2005
    25
    3
    You da man!! :thumbsup: :clap: :thumbsup:
    I would of never of thought of connecting it thru composite changing the system config and then going to component!
    I would of posted sooner but had to play Pro evo 4 via component! :D
  5. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    Yes I am "da man" according to two people on this forum now!! (Hi Dil)
    I am also addicted to PES4!!!! Glad you're up and running bud
