IXOS cables, any difference?
Discussion in 'Cables & Switches' started by markbigears, Jan 20, 2004.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    between the XHV804-300 and the 1703-300 (XHT?) ive seen reports that they are the same, ive just bought a XHV804 from sevenoaks hi-fi, but then saw the other version on ebay, (fillyourboots.com). Ive managed to get a 1703-300 for £35 from them, so rang sevenoaks hi-fi to bring the other one back, which is no problem. Thing is are they the same cable under different numbers. Anyone know off hand before i call IXOS. cheers Guys, mark
  2. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Not sure on the differences, but if fillyourboots is an extremely good ebayer and very helpful. As i understand it, his stock comes direct from IXOS.
    I have bought a lot of things from him with no problems. I had one item that was DOA and he did me a deal for a better cable and free postage!
  3. bobbypunk
    bobbypunk
    They are exactly the same cable
    Ixos a few months back did a major re-packaging and in some cases changing of their products, this is one of the items they changed nothing but the packaging and model number.
    I've seen them selling in shops as old stock for less than £35 though.
  4. MidnightOwl
    MidnightOwl
    Jan 19, 2005
    122
    +5
    Bit late I know,
    But the IXOS web site brackets the 1703 model hence implying they are one and the same.
    http://www.ixos.co.uk/interconnects/index2.html
    Out of curiosity have they made a big impact visually and as well as in your pocket?
    M
  5. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    The cables were the only ones i've used, but can comfirm the DVD image is stunning played through the bose. i robot and T2 look 3D
