I've just bought
Discussion in 'Photography Forums' started by stevegreen, Feb 1, 2005.
  1. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    .... a mount for the top of my mono-pod. :clap:
    Just got to go and vandalise a telephone box now so I can take a picture of it for the February competition :laugh:
  2. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    what sort of mount did you go for?
  3. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    oOe of those multi-angle things. It screws to the top of the mono-pod and then i can swivel the camera through 180 degree's in one direction and 360 degree's in another (i think). It just means that when using the support I can take pictures in portrait mode as opposed to landscape, something i could no doubt fix in PS anyway, but for a tenner does it really matter. It was a Jessops own make.
  4. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    wow! one where you can turn it through 360 degrees? :laugh:
    considering you're using a monopod thats not exactly hard!
    the 180 degrees tilt will prove in handy, does the head have spirit levels in it?
  5. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    :laugh: I thought that was a key feature :laugh:
    No, it's only a chep one! :thumbsdow
  6. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    whats the difference between this and a normal tripod?
    ive got a really old slik one, its built like a brick ****house and does all of thoese things!
  7. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Its a single support ala one of these
    The cam sits on top but it didnt' have any lateral movement so the adaptor allows this :)
  8. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    monopods are a damn sight lighter and a more space friendly than tripods- also gives you more flexibility to pick up the whole lot to snatch different angles... takes some of the weight off (great for telezooms as it also reduces shake)
  9. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,022
    Babel Sensurround
    +207
    How does it reduce shake :confused:
  10. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    so its like an extention stick then!
  11. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
  12. Zone
    Zone
    Jun 24, 2001
    6,736
    Barnsley
    +2,424
    Couldn't be without my tripod, I must admit I've never got along with mono's, guess I'm just a shaky sod :(
    I can understand why the likes of sports photographers use them as they are trying to capture fast action using fast film speeds and fast shutter speeds so the mono cuts down the shake whilst giving them the freedom of movement.
    But for those of us who have a little more time on our hands to set up a shot then a tripod is the only way to go.
    I read about people spending fortunes on camera's and the best lenses then complaining about less than perfect pictures stating they aren't as sharp as they expect, only to then find out they hand held the shot :rolleyes:
  13. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    because you screw the camera (or lens) to the 'pod, which you rest on the ground - stops the end jiggling about all over the shop.
    Off course you've still got to worry about rotating left/right and moving forwards/backwards/left/right :rolleyes:
  14. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,022
    Babel Sensurround
    +207
    But if it only has one leg it isn't going to stay upright on most outside surfaces though :confused:
  15. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Think of it as an extra hand/leg, it gives some stability but you still need to hold the camera.
    They aren't ideal for long exposures, but do really help with fast pans or using long lenses.
    Ian
  16. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    The handy thing about a monopod is that it allows you to use slightly slower shutter speeds without the risk of blurring and without the need to ramp up the ISO or use a very large aperture - but still be able to move about with ease. There are plenty of uses for one - if you've ever tried photographing a wedding in a dimly lit church then you'll know what i mean - a tripod is fine if you want to stay and shoot in one place but for manouverability (i think thats how you spell it) a monopod wins hands down. And of course you'll get a greater number of sharp images than if you were handholding.
    I have to admit though, my tripod gets more use than my monopod. Different tools for different jobs.
  17. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Thats similar to the one I have but with the quick release.
    I preferred a monopod to a tripod as I wanted somthing light and easy to carry as there will be a lot of places that I want to take my camera where a tripod would just be too much. I may have to sort a tripod out in the future though for those 'competition indoor shots' :D
  18. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    You should have saved the money spent on the disabled tripod......... :laugh:
    And put it towards a Canon lens with IS (image stabilizer).. :smashin:
    Hand held at 400mm, you can capture a fast jet aircraft as low as 1/90th second while panning.....no blurr....wonderful.. :smoke:
  19. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Disabled Tripod and attachment £45.00 (ish)
    Canon Lens with IS? :eek:
  20. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    But hey.......its our hobby... :laugh: :laugh: :laugh:
  21. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    True enough, but then again so are speakers, tv's, dvd players, dvd's, cd's, latex clothing, gags, amplifiers, speaker stands blah blah. :laugh:
    I need a lottery win at this rate!
  22. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    As good as IS is I can get better results using a monopod than with the IS lens in low light situations - use both together though and you're onto a winner :thumbsup:
  23. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I try to break my hobbies into 'phases' or 'terms' to ease the cost to the missus.. :laugh:
    Currently still on 'Camera' phase.......
    After holiday to California in June, will probably switch to 'Car' phase.... my 1984 Trans Am not been out on the road since last October.. :eek:
    Willing to skip 'AV/HI FI phase this year if you can give me hints and tips on your 'Latex/Gags hobby.............. :laugh: :laugh: :laugh:
  24. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    :eek: more than we need to know there Steve
  25. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Huuuurrrrrr..... (Bart Simpson syleee). I hate it when Steve 'shares'... :rolleyes:
  26. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    :laugh: :laugh:
    I was wondering if anyone would notice :laugh:
  27. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    What round here they notice if you break wind at your keyboard. :blush:
  28. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    :rolleyes: yeah sorry about that
  29. X_Eyed_Bear
    X_Eyed_Bear
    Well, that's what has put me off buying one of these things. I could spend 10 minutes getting the damn thing to balance, set the camera to timed exposure, press the button, retire hurriedly to stand in heroic posture in front of magnificent foreign scenery, then a puff of wind comes along (or worse still, an incontinent dog) and everyting goes focal plane over aperture.... or is there something I'm missing here? ;)
  30. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    :laugh: erm yeah. It will never stand up on it's own as it's a mono-pod, as in, single support as opposed to a tripod (3 supports). They are designed to give a small amount of support to the camera, unlike a tripod which gives a full unaided support.
