I've got to get me one of these
Discussion in 'Projectors, Screens & Video Processors' started by Roland @ B4, Nov 12, 2001.
Thread Status:
Not open for further replies.
  1. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Just browsing about and came across this and looks like I'm out of business!
    You can convert any size Television, including PC monitors into any size, up to 100” or larger
    All you need are these plans,
    £10 to £15 worth of materials and
    approximately 1 HOUR of your time!
    ANYONE CAN DO THIS!
    No technical skills are required
    All materials can easily be found in any hardware shop
    Ebay link
  2. jrwood
    jrwood
    Anyone know how this works, or have tried it?. I saw this the other week and my first thought was SCAM!
    James
  3. AndyF
    AndyF
    It does actually work, but the results are dire.
    It involves a regular TV, a big box and a lens. You mount the lens in a hole at one end of the box. The TV goes (upside down) inside at the other end. Voila, a very low tech projector.
    Cheers,
    Andy.
Thread Status:
