I've gone and done it now...
Discussion in 'Cables & Switches' started by ali68, Oct 17, 2004.
  1. ali68
    ali68
    Decided behind the TV needed a clean (wow so much fur) I removed the cables and got in with the hoover now I can't put it back together.
    Hubby away at present he tried to explain over the phone but no luck :mad: could someone please help we have the following equipment.
    Hitachi tv= 2 scarts plus comp video i think he said green and blue sockets.
    SonVideo= 2 Scarts
    slvse800
    SonySky= 2 Scarts
    DV3
    Sony DVD=2 scart,vid out,svid out & compv out blue and green thingies again.
    DVP S725D Plus a lot more :rolleyes:
    I'm getting board with just normal terestrial tv :lease:
  2. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,106
    38
    +6
    Sony DVD >>> Hitatchi - Green, Blue, Red thingys ;) For componant video.
    Sky >>> Hitatchi - Scart Lead
    Sony Video >>> Hitatchi - Scart Lead
    Any good to you?
  3. ali68
    ali68
    I'll give it a go, I see no cable from sky to video in your instructions or is this not needed, as for the aeriel cables the sky will go into the Sky box does the tv aerial go into the tv or video? video I presume and out of video into tv arial socket or does the scarts do away with the need for this?
    One more point I see no Comp v cable green, blue etc so I dont think it has been used.
  4. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    :lesson: DO NOT TOUCH ANYTHING BEHIND THE TV... LESSON ENDS
