I've finally gone and done it
Discussion in 'Home Cinema Speakers' started by bob007, Dec 15, 2002.
  1. bob007
    bob007
    Well it's taken me the best part of a year but I have finally got a full matching 6.1 system.
    Polk Audio:
    Fronts L/R RT600i's
    Centre CS400i
    Surrounds F/X500i's
    Surround Back RT25i
    Just thought I would post my findings as it may help others when thinking about purchasing speakers/packages, also a mention on Direct radiating/Di/Bi-poles for surrounds and positioning of the surrounds/surround backs.
    I started with the Polk floorstanders and Polk centre giving preference to the front soundstage, I was on a budget like so many of us and couldn't afford the full system, I already had a pair of Tannoy MX2's for the surrounds so decided the quickest and cheapest way was to buy another pair for the surround backs, at least the back soundstage was the same even though it didn't match the front. I then found the centre (CS245) was being out classed by the main fronts so I upgraded to the much larger centre, in fact I was more worried that the centre would outclass the mains, the CS400i is a monster, weighing in at 30lbs, but it's size and weight only helped it to make all the difference, when I played the test tones across the front the sound from each speaker was now identical so I knew this was to be a better match. The proof would be when listening to a movie, especially dialogue, there's nothing worse than having dialogue lacking in depth from the centre then it sounding like James Earl Jones from the mains. So after a few demos I sat back in the knowledge that I had chosen the right speaker this time as there was no tonal change when listening to dialogue/cars/trucks/planes etc when it's being steered through any of the front speakers.
    This just left the rears, I started with the surrounds so at least when I was listening to 5.1 the system would match, I wanted to choose the right speakers for this (having learnt my lesson earlier with the centre speaker), so I looked mainly at the drivers and selected the ones that were the perfect match to the fronts, this was so that any soundtrack with steering from front to back, back to front etc there wouldn't be noticeable change in the sound tonally. The results were perfect. The system was coming together nicely. :D
    Only the surround backs to go and this was where I started to get confused, do I swap the surrounds and place them at the back for the surround back duties and buy a pair of Di/Bi-poles for the surrounds, or just buy another pair of RT25i's and be done with it. There has been a lot of discussion just recently on the subject of Di/Bi/Tri-poles, some love them, some loathe them, so I decided to give them a demo, I was pleasantly surprised, not the mish mashie sound I always thought they would produce but the F/X500i's gave a very clean sound just what I was looking for. The clip from Twister did it for me, listening on my system with the RT25i's the sound of the wind whistling round the room tended to be coming from two open windows to the left and right of me and not all around, but with the F/X500i's you were sat right in the middle of the tornado. These speakers have the option to produce a more direct sound if needed, maybe for music, all you have to do is switch them to Bi-pole, I listen to music via Direct/Stereo so for me I can't see me switching it to any other setting apart from Di-pole for the time being anyway. Now to my last decision, shall I use a single speaker like I am doing at the moment or a pair of speakers like I have done in the past for the surround backs? I still have the same view on this, if the pair are being feed the same mono signal and have to be positioned just about on top of each other why bother with a pair so I have stuck with the single surround back for now, at least I won't have to spend more money upgrading as I have the other extra speaker when 7.1 does finally arrive.
    Saturday night was the first time we were able to sit down and watched a movie on the completed system, Sum of all Fears was the choice; all I can say is WOW! Such a difference, everything just blends in, you can really tell the difference from a full matching speaker system to one that has been put together from different manufacturers.
    As for the positioning, the surrounds which are in Di-pole mode are on the side walls approx 90cm above ear level when seated and level with the listening position, the surround back is directly behind the seating position approx 2m, it is slightly higher than the surrounds and I have also angled it downwards very slightly.
    Yes it has taken the best part of a year to get to this stage but it has been worth it. :D
  2. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Well done,
    sounds like a nice system :)
    I've still got some horrible old floorstanders for the rears and no centre so a long way to go yet :)
    Dave
  3. bob007
    bob007
    Thanks Dave.
    If you have the will power to wait it is well worth it. I could have bought a full system with the money I paid out for the fronts, but upon hearing the Polks I decided that a full system with these in my room was what I was really after, so for once I was determined to wait, the year went fairly quick, being on the forums passed the time. :D
    Forgot to mention, to complement the Polks I bought a Velodyne CHT-15, all these are run by a Denon 3801.
    Next addition will be a Rotel 1085, roll on the next 365 days. :)
  4. bob007
    bob007
    Excuse the xmas decorations.
  5. bob007
    bob007
    Cover on
  6. bob007
    bob007
    Cover off.
  7. bob007
    bob007
    Going to try the two surround backs, but will have to wait till after all the decorations are down, (missus started to object strongly, something to do with the dust from drilling :( ) plus the sub had to be moved to make way for the bloody christmas tree, want to get that back into the right position before I start with sound tests.
      Size:
      5.7 KB
      351
  8. bob007
    bob007
    Eat your heart out all you Pro50/Servo 15 owners. :p
    The much talked about and respected sub, the Velodyne CHT-15. :D
  9. uncle eric
    uncle eric
    Very nice Bob. Neat install as well. Fancy a lodger for xmas :D
  10. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,101
    notts.
    +73
    hi bob007
    where do you position your sub
    thanks gonzo
  11. bob007
    bob007
    Learnt all my DIY skills off those blokes on the telly, those "Big Strong Boys". :D
    Pop in, you will be well looked after, we have plenty to eat and drink.
    The sub is in the other alcove to the left of the TV, we are thinking of having the chimney breast knocked out, then we will have a flat wall approx 22' to play with, won't be so cramped up.
  12. uncle eric
    uncle eric
    What a gent. Have a lovely xmas Bob
  13. bob007
    bob007
    Thanks Eric, best wishes to you and the family, hope you have a great new year as well. ;)
  14. Smurfin
    Smurfin
    Aug 13, 2002
    21,443
    +4,387
    Pro50 and Servo 15 uttered in the same breath? LMAO, oh man you have a sense of humour;)
  15. Smurfin
    Smurfin
    Aug 13, 2002
    21,443
    +4,387
    btw nice set-up matey....:)
  16. Lowrider
    Lowrider
    Now all you need is a room where you can place the speakers properly... ;)
  17. bob007
    bob007
    Yeh, similar to how you have yours. :p [​IMG]
  18. Lowrider
    Lowrider
    Never thought of that... hmmm... :rolleyes:
  19. Geoffrey Shrek
    Geoffrey Shrek
    Thats true. The Pro 50's are reliable :D
  20. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    (puts head on block)
    I have to say that all this Servo is crap Velodyne are wonderful stuff is an absolute bloody nonsense and not what the purpose (or spirit) of these forums are designed for.
    I wonder how many Velodyne owners have actually listened to anything else (than perhaps the odd REL or PRO-A) and indeed have been sold a product without even listening to it (laughable/amatuerish!!).
    This sort of thing is mis-information and i tend to think that alot (but not all of course) of these posts are by people who should perhaps try to understand a little more about a subject before making definitive statements.
    Steve
  21. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    For the record i have spent time with perhaps 25 - 30 subs.
    Steve
  22. Harold Corbet
    Harold Corbet
    Then you should know M&K make the best :D
  23. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    The original post was about someone's Polk installation that happened to include a Velodyne subwoofer. One or two light hearted comments have been made since, but it is only your post that is not in the spirit of the forums.
    I speak as the owner of one of your "odd RELs"
  24. Guest
    Bet your bird loves that!....
    Trouble is, there's not enough room in a bed for a Servo 15 , you & a young lady.....These bed manufacturers need to start thinking about us sub owners......
    Adzman...
  25. Lowrider
    Lowrider
    Buy one of those american beds that vibrate... ;)
  26. NicolasB
    NicolasB
    Oct 3, 2002
    6,584
    137
    Emily's Shop
    +956
    Or just buy a normal bed and stick an HGS-18 under it.:rolleyes:
  27. Charlie Whitehouse
    Charlie Whitehouse
    Or if you really want the earth to move, try putting it on one of these! :devil:
  28. chips
    chips
    Dec 3, 2001
    2,404
    2NM S EGTF
    +25
    Hmmmm, could be dangerous if you’re watching a bluey:eek: :eek:
