I've done it! I've only gone and bloody done it!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by morgs, Nov 30, 2004.
  1. morgs
    morgs
    Nov 27, 2004
    175
    +3
    Yes, after much to-ing and frow-ing, and some great advice (much of it very patient from you guys)
    I've bought my first DVD recorder (fanfare please!)
    I've bought the Panasonic E55 (region 2. I've never actually needed a multi- region machine before even though I've had one for three years)
    Now I need some more advice please (before the fun starts when I get it out of the box)
    Any owners of Panny E55's out there who can tell me which are the best dvd-r discs and RAM discs to use
    Obviously Pansonic discs should be fine, but they come at a premium!
    Thanks in anticipation
    Morgs
  2. Bosco
    Bosco
    www.svp.co.uk sell ram disks made by Ritek, it cost me €20 for 10, apart from that you can get ritek G04/05 -R disks for about £7 for 25, these work fine on almost any player.
  3. morgs
    morgs
    Nov 27, 2004
    175
    +3
    Thanks for that!
    Would I get any benefit at all from using premium brand discs
    (if I'm giving discs to family, I don't want them failing)
    Morgs
  4. Dannytuba
    Dannytuba
    Sep 14, 2004
    11
    Morgs
    How far did you get with ordering discs?
    I took ownership of my E55 dvd recorder yesterday and want to start copying films.
    Is it worth paying for nemed brands?
    Danny
  5. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    In my (not inconsiderable) experience with Panasonic recorders they tend to be happier with Japanese ‘quality’ media such as TDK, Taiyo Yuden, MCC (Verbatim), etc. These are class 'A' discs. I get 100% burn rates with these. As for longevity, who knows? It comes down to the type of dye used. but I doubt that discs which have flaws during manufacture would last as long as ones which don't.
    See:
    http://www.digitalfaq.com/media/dvdmedia.htm
  6. Tra300
    Tra300
  7. Bosco
    Bosco
    SVP sell preimum grade A disks which were made using the Ritek GO5 dye (which is regarded as a quality dye) but are now using the MCC dye (again quality). For the money that they are asking for a pk of 25 (about £7) I don't think that you can go wrong. Even if every second one fails (and I have no problems with them at all) you will still get more for your money compared to buying TDK etc. In reality most of these manufacturers use the same (or very similar) dye, differences in costs come from branding and marketing costs associated with "named" companies.
  8. morgs
    morgs
    Nov 27, 2004
    175
    +3
    That sounds good to me!
    25 disks for £7!!!
    Have you got a link to the right product??
    Morgs
    Ps Anyone got a brand of cheaper DVD-RAM disks that are reliable?
  9. Bosco
    Bosco
    This is the link to the general page http://www.blankdiscshop.co.uk/acatalog/Show_me_all_the_DVD_R.html
    You should be ok with any of the following:
    {DV 3141} ANV Ritek A-Grade (8x) DVD-R in Packs of 25
    {DV 3164} Ritek Ridisc A Grade (4x) DVD-R Disc in Packs of 25
    {DV 3169} Verbatim (8x) DVD-R Disc in Spindle Tubs of 50 (£27 for these)
    {DV 3129} Pack of 5 Verbatim (4x) Pastel Coloured DVD-R (With excellent Taiyo Yuden dye) in Slimline Jewel Cases (less than £3 for a 5pk)
    {DV 3173} CMC Tango (4x) DVD-R in Spindle Tubs of 50 (These have the CMC dye and should be fine, at under £10 for 50 you can't go wrong)
    Let us know how you get on.
    I have personally used the Ritek GO5 dye disks and these have worked fine for me in my machine (and several others that I have tested).
  10. morgs
    morgs
    Nov 27, 2004
    175
    +3
    Cheers Bosco, I'll give them a go
    Morgs
  11. Bosco
    Bosco
    No problem and the service from SVP is fantastic too :thumbsup:
  12. alicat
    alicat
    Oct 13, 2004
    92
  13. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    +34
    dut....duddludud...dut...dut...dut...dut...dut...dut...dut...dut...deeeeeeeeeeeeeeeeee
    :laugh:
  14. morgs
    morgs
    Nov 27, 2004
    175
    +3
    Thank-you for that truly wonderful tribute!
    My machine and I are both sooo proud!
