I've bought a Tag!
Discussion in 'AV Receivers & Amplifiers' started by CounterWhine, Feb 3, 2003.
  1. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Hi All,
    I've just bought an AV32R! I'm so excited, I just had to tell someone (everyone).
    D.
  2. dgj
    dgj
    Jammy git:smashin:
  3. AOD
    AOD
    Feb 7, 2001
    710
    London
    +4
    Congratulations. Welcome to the club! :smashin:
    What's the rest of your kit if you don't mind us enquiring?
  4. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    It's in my signature (see below).
    The Tag's black and has the 192KHz DACs, Pro-Logic II and HDCD but not the analogue bypass so I guess it's a AV32R192. I bought it factory refurbished direct from Tag with an 18 month warranty.
    D.
  5. AV Geeza
    AV Geeza
    Oct 10, 2001
    395
    Londinium
    +3
    Hey DavidR,
    Nice set up! :smashin:
    Im sure you'll have endless hours of great viewing!!!! :zonked:
    Geeza
  6. AOD
    AOD
    Feb 7, 2001
    710
    London
    +4
    Indeed, nice setup. Once again my hands are faster than my brain... :(
    Enjoy!
  7. Taz
    Taz
    So what! who cares!......................................
    Only joking mate!:D Lucky you! hope it sounds great!:smashin:
    Taz.
  8. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Congrats.....good gear,and should give you loads of fun....mine certainly has. :clap:
  9. JSW
    JSW
    Feb 21, 2002
    4,235
    Staffs
    +320
    alex,
    do you use your av32r for av or just music?
    If av how did you set it up, internal tones or setup cd/dvd ?
    Bry
  10. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    JSW......I use my AV32R for music and AV,and basically just used the Tag setup wizard and an SPL meter for level matching.
    In terms of music(i.e.CD playback)it's good,but much better when the DACs are run at 24/96 using the PT upsampler/interpolator.
    The AV setup couldn't have been easier,compared with the fractured Japanese/English supplied with the Denon receiver I'd had before.
    The only thing that did require a bit of fiddling around was the bass management,to get the sound right in the room,which has lath and plaster walls(250 yr old house to contend with!)
  11. JSW
    JSW
    Feb 21, 2002
    4,235
    Staffs
    +320
    Thats why I asked, I had a nightmare getting the sub integrated.
    In the end had to turn the gain of the sub down and then set the output on the Tag just so it would turn on the sub.
    Then when sub and mains where both at 75db it still didn't sound right and had to turn sub gain up a couple of notches.
    Sounds much better now but with some music I think the sub could do with going down a notch.
    Bry
  12. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Interesting seeing your experiences with the sub integration,JSW....I'd previously had a set of Linn Keltiks that I just couldnt get to work properly in the house we'd moved to...they worked fine in the last house,which had brick walls and a suspended wood floor,but no way would they tune into this house.....the only way to use them at all was to roll off the bass at 40Hz,and trim back the level as well.....so they were eventually sold to make way for the current AV system.
    Then began the next set of problems integrating the sub....I'd chosen a REL after demoing a lot of subs at home and finally found one that worked OK in a 250yr old house,and had sufficient adjustability to ensure that.
    As for music and bass Eq....I think a lot of CD's,esp chart CD's,have excessive upper bass eq added to make them sound better on cheap boom-box CD players,and rolling that off again for home consumption on good gear is a pain.
  13. JSW
    JSW
    Feb 21, 2002
    4,235
    Staffs
    +320
    I still have a prob with the sub which is a peak at 36Hz.
    As I can't play around with the position looks like I may have to get the feedback destroyer to get rid of it.
    Last resort i know but apocalypse has had success with his.
