Itv hd ch4 hd
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Beaker, Feb 9, 2009.
Tags:
  1. Beaker
    Beaker
    May 4, 2002
    96
    11
    York
    +7
    I've got my Panny 46pz81b set up, i had a 42pz81b on order from Empire direct and they the went bust.
    BBC HD is on freesat Ch 108 but what channels are ITV HD and CH4 HD on. I can't spot them.
  2. Mikewebb
    Mikewebb
    Dec 5, 2007
    599
    Leeds
    +53
    There is no C4 HD on Freesat and ITV HD is on the normal channel via the red button when prompted
  3. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    ITV HD is a red button service. When something is available in HD on ITV1 you should get a red button prompt, press the red button to switch to the HD feed.
    CH4HD is not currently available on Freesat, only on SkyHD.
  4. quattro_man
    quattro_man
    Aug 9, 2006
    29
    3
    You can get C4HD if you use a CAM and a SlY freesat card. You will need to set the Foxsat to "non freesat" in its menu.
    Peter
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,542
    Redditch
    +4,187
    Don't think the Panny TV has a CI slot for the sat tuner (I might be wrong)
  6. col996s
    col996s
    Nov 16, 2008
    267
    +8
    What does this involve? I have the Humax foxsat box (not HDR) and would love to get CH4 HD.
    Thanks in anticipation.
  7. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,542
    Redditch
    +4,187
    You can't do it on the HD it does not have a CI slot. (The hdr does)
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,609
    4
    Aldershot, Hampshire
    +330
    I have an HDR box and would be interested in getting CH4HD. Can you explain what's needed/involved please.
    thanks
  9. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,542
    Redditch
    +4,187
    In all honesty I don't think it's worth the hassle. You need a dragon cam (around £100.00) and a working sky box with a freesat from sky card. Using the dragon cam you can tune and view CH4 HD in non freesat mode using the card from the sky box but you need to put the card back in the sky box every 4 weeks or so to keep it alive. With CH4 HD likely to appear on freesat later this year I think it's a bit of a waste of money, especially as you can't set recordings in non freesat mode.
  10. mwallan
    mwallan
    Jan 20, 2003
    987
    +78
    With sky about to change there cards its not best to buy any cams yet as they may not work with the available cams
  11. The Spaniard
    The Spaniard
    Jan 2, 2001
    1,105
    Walsall
    +80
    Do we have any idea/best guess when C4HD will be available on freesat?
  12. jamesy999
    jamesy999
    Jan 9, 2009
    271
    Middlesbrough
    +15
    Graham will any Dragon cam work or does it have to be the latest. Will for example a 3.69 version work?
  13. pdoherty76
    pdoherty76
    Dec 25, 2008
    2,435
    +70
    Last we heard was that Channel 4 themselves said they "hoped" to have CH4HD on freesat by the end of the year. its possible, but nobody really knows. its clear CH4 are working on it, but they are in contract with SKy and there isnt currently space for it to go FTA.
  14. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,542
    Redditch
    +4,187
    Sorry not a clue :confused:
  15. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The Predator 3.59 works fine in my T-Rex so I assume an updated version (may not have any benefit for SKY's Videoguard) should work fine however as mentioned this is probably going to be thrown out the window when the new smartcards are rolled out.
