ITV Football last night Man Utd v Juv
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mansell, Feb 20, 2003.
  1. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    Is it me or was the broadcast quality very poor on ITV via SKY ?
    Really bad actifacting on the pitch , ghosting around the players etc
    did you find that the Pic quality was much better on ITV terrestrial even though the picture was a bit noisy of course ?
    any thought's ?
    bad compression I guess ?
  2. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    The picture was perfect via the aerial (ITV analogue). It always is for the 5 terrestrial channels on our telly. Weird.
  3. perrdl
    perrdl
    Jul 29, 2002
    357
    19
    Worcester
    I watched the first half on Sky and it seemed OK to me!!!
  4. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    could it be my TV , I've just had it changed again and I must admit I'm not 100% happy with the picture anyway .
  5. Fernsehman
    Fernsehman
    Is the TV set compatible with Sky Digiboxes? A lot aren't. Get the shop to demonstrate before you buy!
    This is especially so if you are using RGB via scart.
    Fman
  6. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    I've had two replacement's for this TV now for varying problems , this third one just seems to struggle with poor reception through RF or badly compressed sky channels .
  7. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    I have the same TV and I'm not over-impressed with football on Sky digital. It's worse for me on ITV so I tend to watch through terestrial. To me it appears like the players have a kind of "heat haze" around them
  8. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    Hi JohnG , so you have a PB50 also ,which one 32" or 36" ?
    Do you find sky football to be alot better than ITV premiership \champions league ?
    I'm sure it's the source as DVD playback is superb .
    how far away to you sit from your TV ,i've heard it has to be 5 times the screen width , we sit about 6-8 feet away but last night it still looked bad on ITV via sky with the heathaze you mention and the pitch looking like a billiard table sometimes
    Other channels however such as the moive channel's,sky news are much better ,highter bit rate I presume , do you find this the case also ?
    do you get the dirty screen problem ?
  9. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    Mine's the 32"
    I do find Sky sports football to be a lot better than the ITV stuff. I'm finding exactly the same - it depends on the source. DVD, as you say, is superb and the better Sky channels are excellent too. I sit about 12 feet away.
  10. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    In addition to this, I've tried better scart leads (Ixos) and it makes no difference.
  11. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    that's Disappointing to hear as I’ve got a ixos 141av on order to replace one of my free cables . I was hoping it would improve things .
    do you get the dirty screen problem (looks like your looking through a dirty window) , it's only obvious when the image pan's across a pale colour,like football
  12. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    Not sure about the dirty image.
    What I have noticed is that if I'm tuned into say bbc on analogue and then press the av button to watch sky I can quite often see things going up the screen. I've pinned it down to when credits are running on the analogue channel - there must be interference from there. You can get around this by switching to a non tuned in channel before pressing av.
  13. CatDog
    CatDog
    Apr 20, 2001
    94
    Midlands
    Re the problem with 'Ghost credits' - I suffered from this for ages until I stumbled across an article about how pin 19 on a Scart can cause this because it feeds back composite video from TV to digibox. I took out the pliers, disconnected it and Hey presto - problem solved !
    Theres a diagram here http://www.daveladd.demon.co.uk/pscart/scartpinout.html
    PS I also have same problem with ITV footy = I assumed it's low bitrate due to multiple regions.
  14. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I also find that the picture quality can be better via terrestrial, but unfortunately it isn't in 16:9 :( So you either have poor quality in widesceen, or good quality in 4:3 :rolleyes: :mad:
