ITV 1 - now on sky official !!!
Discussion in 'Sky Digital TV Forum' started by Bone Daddy, Nov 21, 2001.
  1. Bone Daddy
    Bone Daddy
    May 1, 2001
    502
    west midlands
    +3
    Just 5 min`s ago,flicking through the tv guide then it went into searching for channels mode and when it came back there was ITV 1 in the epg guide,and it works to boot :D
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    I'm at work so I can't check.
    Any sign of ITV2 on the EPG ?
  3. Spencem
    Spencem
    Oct 15, 2001
    204
    Northampton
    +11
    No sign of ITV2, however on 963 and 964 I've got my two nabouring regions Central and London. All three are broadcasting in 14:9:(
  4. Mark P
    Mark P
    fantastic
    103 now = central
    and you can still tune into the other regions which means i can watch the arsenal match on itv1 london tonight.
  5. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Are STV and Ulster still pumping out widescreen pictures ?
  6. Guest
    Yes UTV is W/S also ITV 2 is working
  7. Mark P
    Mark P
    i have just read that ITV2 will be officially launched on sky digital channel 226 by monday. Until then you will just have to put up with the test channel transmissions.
  8. Doubledoom
    Doubledoom
    No widescreen in Anglia and no ITV2, although i wasn't expecting that as it isn't launched for a few more days.
  9. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    could some one explain how to get itv2 ive tried everything. im going to throw the box across the room soon:confused: . I can get itv1 fine.
  10. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Did you add all the channels that were available with the freqs that the ITV channels were on ?
    If you did then I believe ITV2 is the one labeled 3-5
  11. bob007
    bob007
    10906 V SYMBOL RATE 22.0 FEC 5/6....... 3-5 = itv2
  12. Guest
  13. Paden
    Paden
    Jul 27, 2000
    578
    +23
    Hello all!
    Anyone know what's with the 14:9?
    Good to have it Sky at last but I'm sure that the tests I'd seen were in widescreen.
    Cheers, Paul.
  14. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    when i have saved these channels are they ment to show up on the tv guide. Sofar i get none of them:(
  15. Doubledoom
    Doubledoom
    The early tests were anamorphic widescreen but went over to 14:9 a few days ago on the tests.
    Only ITV should appear on the EPG. ITV2 and the other test channels you have located will not appear on the EPG but will appear in the other channels section.
  16. Guest
    No access is Via Services and button 6 other channels
  17. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    ignore the post above ive just been to the site big pasty put a link to and found the answer there
    Thanks for your help
  18. Bone Daddy
    Bone Daddy
    May 1, 2001
    502
    west midlands
    +3
    ITV 2 are broadcasting programes on the 3-5 freq`unlike yesterday were they switched them of at about 5.30pm after 2 hours,are they still showing the "Letterman"show ?? on this channel,this was one of the reasons I wanted ITV digital when they first started but held off because of the price of the box :eek: Good news about ITV 2 starting as well on monday.this makes things so much easier now that everything is in the same box :D no having to switch the tv over,change the amp to tv,alter the video settings if you ever wanted to tape anything (Coronation st for the :kisses: ) nice!!
  19. Guest
    Cant believe ITV London are broadcasting a 14x9 letterboxed picture on SKY.....as if that isnt bad enough, the footy which is on at the mo has "curtains" at the sides, making the picture even smaller!!
    WE WANT ANAMORPHIC!!
    ps...completely off topic...how do you insert those little personalised piccies at the top of your postings eg bone daddy?
  20. bob007
    bob007
    They are called avatars. Go to user cp then edit options then at the bottom you will see it labeled avatar. You can do a search for your own personal avatar on a search engine.
  21. Guest
    Yep...that appears to work!
    Thanks....
    I emailed ITV yesterday asking them why they have chosen to broadcast in 14 x 9 which is a crap compromise - 14x9 looks naff on a 4x3 AND 16x9 screen...so who are they trying to please?
    I suspect SKY asked them for 14x9 broadcasts, seeing as how they are so relucant to give us any more widescreen material....
    Perhaps if everyone emails ITV they will relent and give us anamorphic pictures - their website is www.itv.com
  22. Berno
    Berno
    Feb 28, 2001
    43
    North West England
    I have just emailed ITV about the picture format too.
    I hate 14 x 9 :mad:
  23. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
