Itunes5 - Restriction
Discussion in 'iPhone Forum' started by paulrwebster, Sep 7, 2005.
Tags:
  1. paulrwebster
    paulrwebster
    Jan 8, 2005
    92
    +3
    This is hidden away in the installation program:
    Important: After installing iTunes 5, you will only be able to transfer music to your iPod using iTunes. To transfer music from MusicMatch Jukebox or Audible Manager to your iPod, you will need to first import the music into iTunes. For more information, search "iTunes and Music Store Help."
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,244
    +64
    Sharepod still works fine and that was updated before the release of iTunes 5. There's clearly been no major change in the way the database is structured. Maybe for DRM stuff it's different... I don't know.
