rustybin
I use smartdns at home. Windscribe out and about.Ok thanks I still can’t get in but will give it a few hours. Which VPN are you using to redeem?
Yes you need a VPN to setup the Movies Anywhere account, there’s a few methods mentioned in the FAQ in post 1.So setting up a Movies Anywhere account.
I've created the US iTunes account, added it to my Apple TV and downloaded the app.
Trying to create an actual account. Do I need a VPN to create one? I'm a bit lost.
Yes you do.So setting up a Movies Anywhere account.
Unless of course you know someone in the States then just get them to set it up for you.Cheers folks. I've never used a VPN in my life, but I have a day off on Thursday so guess it's time to learn!
Good thinking.Unless of course you know someone in the States then just get them to set it up for you.
If you're struggling, send me a PM with an email address, and I'll see if I can set an account up for you.Cheers folks. I've never used a VPN in my life, but I have a day off on Thursday so guess it's time to learn!
It's on my list to learn. Just need to get my head around it. I used to be totally on top of things, but the world has passed me by somewhat. It's a tad tragic. I'm getting old.If you're struggling, send me a PM with an email address, and I'll see if I can set an account up for you.
However, in any event, I'd recommend getting to grips with a basic free VPN like Windscribe in due course, as all the best digital movie deals at present are for Vudu Instawatch titles (many of which port to MA) and you need a VPN to access Vudu to create an account as well as to redeem these.
If it is an actual HD iTunes code then it should redeem in 4k at iTunes. Some codes are sold as iTunes but they're actually MA codes which will pass through to iTunes.I just wanted to say publicly a bit thank you to Andrew for helping me out with a Movies Anywhere account. Saved me a lot of time (and no doubt swearing) so thank you. Credit to the forum.
Last question now. Promise. I get the part about buying direct from iTunes means it can be upgraded to 4k as/when an upgrade is available. I wondered if I specifically buy what is advertised as an itunes HD iTunes code, when a 4k version is already available will I get the upgrade or would I be right thinking I wouldn't as I have chosen to buy the HD code? Punishment for being cheap.
Thank you again Andrew, and cheers to all who have answered my questions so far. I am grateful.
Just replied to your PMHeya.
Can anyone set up a MoviesAnywhere account for me?
I've tried various vpns and nothing works, not even my trusted expressvpn.
I'm really wanting to redeem my The Hobbit trilogy and it just won't let me sign up, so I can't connect my vudu to the MoviesAnywhere.
I would be so happy to get that in order.
Go to Google Play and then redeem by clicking the link on the left hand sidesorry but i have been looking for a while before i posted, looking to redeem a couple of aus codes into my sons google account, now i have done this before loads of times but now am stumped can anyone help i think it was something like change the country code on google but i cant find the link to it
Not working wrong country also tried changing the uk in the address to aus and going through vpn but still nogoGo to Google Play and then redeem by clicking the link on the left hand side
