ITunes Play Count
Discussion in 'iPhone Forum' started by asimm, Oct 18, 2005.
Tags:
  1. asimm
    asimm
    Aug 3, 2000
    1,516
    48
    +75
    Like to keep track (no pun intended) of my most played. Upgraded to ITunes 6 and all the play count scores have gone crazy. Now have a certain George Michael on 80 (yes I know what was he doing in my libary to start with). Anyway, after months of building up my play count I now need to reset it. I think there is this option but can't find it. Have done a forum search and no luck there.
    Anyone any ideas?
  2. HMHB
    HMHB
    Nov 11, 2001
    27,586
    Nottinghamshire
    +6,526
    The easiest way I've found is to sort the tracks in play count order by clicking on the play count column in library view and then select the tracks you want to reset (if you want to do a multiple select you can click on the first one and the press shift whilst clicking on the last one). Then if you right click you will see an option to reset the play count for the selected tracks.
