Itunes - Ipod MP3
Discussion in 'Headphones, Earphones & Portable Music' started by SHANE33, Dec 28, 2006.
Tags:
  1. SHANE33
    SHANE33
    I have downloaded Itunes for my ipod , i would like to change the format from ACC to MP3 , how do i change :)
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    DBPoweramp
    altohugh you should be aware that every time you transcode from one format to another you are reducing the quality.
  3. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    Not sure if this is what you mean:
    Click 'Edit' in the Tool bar, and then hit 'Preferences'
    Click the 'Advanced' tab, and then the 'Import' tab.
    In the box that says 'Import Using' click on the drop down menu and select 'MP3 Encoder'.
    You can use the 'Setting' drop down menu to select your bitrate.
    This will now mean any CD's you rip will rip into MP3 at the selected bitrate, and you can use Itunes to transcode your unprotected AAC files to MP3 as well (although as mentioned above you will slightly lose quality)
  4. SHANE33
    SHANE33
    I am using MP3 at (192kbps) or is ACC better ?
  5. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    At the same bit rate AAC is better, in terms of sound quality. However, remember more players will recognise MP3.
