iTunes crashing?
Discussion in 'iPhone Forum' started by thx25, Jul 26, 2005.
Tags:
  1. thx25
    thx25
    Have had an issue where iTunes doesn't repond when it reaches the last track when importing a CD.
    Using Windows XP and the latest version of iTunes.... any help?
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,219
    48
    +61
    Any CD or a particular one?
  3. thx25
    thx25
    Not really mate but always the last track.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,514
    Nottinghamshire
    +3,851
    Do you have access to another cd or dvd drive ? It may be that the drive you are using to read the CDs is faulty
  5. kingrizla
    kingrizla
    I had a similar problem with itunes, BUT mine crashed on the first track each time. It was due to a small utility programne I had installed that was running in the backgroud. Once I had disabled it everything was ok.
