Itunes, clipping my music
Discussion in 'Apple Forum' started by Bacus, Mar 2, 2013.
  1. Bacus
    Bacus
    Dec 30, 2004
    8,959
    Close to the sea
    +2,912
    My iMac is now all set up, I have downloaded my iTunes records and have home share turned on. But I have noticed that every song I have now got on my iMac has been clipped to 1min 30 seconds.
    Has anyone else found this ?
    Everything is still ok on my ipad & iPhone with the songs listed with there length of play. Is there a fix for this ?
    Regards Bacus.
    I
  2. MiiCK90
    MiiCK90
    Nov 5, 2011
    855
    Newcastle
    +22
    If you click on the song, hold down ctrl + click, get info, then options, is the start/end time checked, and the end time set to 1min 30?
    You could quit itunes (click itunes next to apple, quit itunes), then hold down ALT and open itunes, select create library, and import your songs into here and see if they're fine, or remove all the songs from your itunes library and re-import, see if that works.
    Otherwise, use this:
    http://dougscripts.com/itunes/scripts/ss.php?sp=resettracksstartstop
  3. Bacus
    Bacus
    Dec 30, 2004
    8,959
    Close to the sea
    +2,912
    Thank you, all working now
