itunes - awful sound quality
Discussion in 'iPhone Forum' started by Cardiff Irons, May 4, 2005.
Tags:
  1. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    Thought I'd try out itunes and SS3.1 as a precursor to possibly buying a portable. Had old version SS on my laptop already (Sony Vaio) and upgraded to 3.1, itunes had to install from scratch.
    And....the sound quality playing tracks on itunes is diabolical. All distorted and unlistenable - I'm not talking about poor quality, I mean it's awful. Has anyone else experienced this?
    I even tried reinstalling, but no better.
    BTW, sound quality of same tracks on SS3.1, Windows media player etc. is fine. :confused:
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    Land of the Living, Essex
    +33
    yup, its crap, foobar is your friend
  3. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    No problems at all with iTunes for me mate. What bit-rate are the tracks you are playing ?
  4. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    Various John, but mostly I download at 320kbps, so should be OK. But the sound was just as bad from a CD - it was awful.
    It feels like there must be a setting somewhere that's wrong....or maybe my Vaio is designed to mess up itunes, therefore forcing me down the Sony portable route ;)
  5. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    Try turning off or on the Sound Enhancer option in Preferences, depending on how yours is set.
    There's also a setting in Quick Time under Sound Out (access this via control panel) try changing that to see if it makes a difference.
  6. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    You're a genius John. It was indeed the Quicktime setting - now changed and all's OK. Many thanks. :smashin:
    Now to get down to some serious itunes and SS3.1 comparisons.
