Question iTunes Alternative
JayCee
For use on what? iPhone/iPad/Mac or PC?
To listen to music?
iTunes is no more, it's been replaced by the “Music” app.
electech
I will be using it on an Iphone X and an IPad Pro, today I downloaded a free trial of WinX Media Trans to try out.
So far with limited use of it, it looks as if it might do the job.
The downside of it is I cant seem to store everything in the program on the PC, as I could do on the old ITunes.
Steven
Senior Moderator
It is only for Mac OS that iTunes is no more and spun off into separate apps for music, podcasts, books etc
iTunes still exists on Windows
bransoj
I dont really get the hate for iTunes, i've always got on with it and found it pretty easy to use. I dont need to use it as much these days as i have Apple Music but prior to this i always found it pretty simple for getting music onto my phone, doing back ups, updates etc.
electech
I was under the impression that the changes to ITunes was across all platforms, but as I am using Windows 10, I will continue to use it. Thanks for putting me straight.
electech
I feel the same as you and have had no problem with ITunes. As I mentioned in my previous post, I was looking for an alternative as I thought it was going to be scrapped.
bransoj
iTunes lost the ability to download apps to install on an iPhone/iPad or change your home screen layout but as it stands you can still use it to organise your music, do back ups, iOS software updates, restores, add files into other apps that allow it.
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
