It's driving me nuts!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by maze, Jan 12, 2002.
  1. maze
    maze
    ...my DVD player,that is....the problem is the TV screen (Phillips portable) goes blue after about 30 seconds of playing and continues to go from a blue screen to the movie and back again every minute or so for the remainder of the movie...making it un-watchable (sp?)...
    Everything is connected correctly....the DVD player (Oritron 600) works perfectly on every other TV in the house, except the Phillips combi portable! I have tried at least 7 different dvd's in the player....I've tried retuning, cleaning the discs, pulling my hair out etc...still no luck...
    Any ideas ?
  2. Ten
    Ten
    Jul 1, 2001
    163
    16
    UK
    Stab in the dark, but could it be macrovision causing this as you have a combo jobbie. what inputs r available? can u bypass the video ie is there an input direct into the tv?
    Ten
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Ten is correct, it will be the macrovision copy protection in your combi TV that is causing the problem.
    Macro busters are available for about £30
  4. maze
    maze
    Thanks guys....haven't got a clue what Macrovision is...but the only output on the tv combi is a lone scarf socket......nothing else...Unfortunately,there is no way to bypass the video ...
    Cheers....
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Macrovision is the copy protection device used on all DVDs to stop them being copied.
    It works by interfering with VCRs and the result is normally a flashing picture which flashes from bright to dark.
    This means that you cannot connect up a DVD player by routing it through the spare scart socket on a VCR.
    It also seems to have side effects when plugging a DVD player into a combi
  6. Keithd50
    Keithd50
