Its all gone pink!
Discussion in 'Blu-ray & DVD Players & Recorders' started by sideshowbob, May 30, 2003.
  1. sideshowbob
    sideshowbob
    Have a Panasonic A360 DVD player connected via a quality scart cable to 32" sony widescreen TV.
    No problems until now - kids stuck a dvd in and all the whites are showing up pink on the tv. TV is okay on all other inputs - seems like the dvd player is not outputting colour correctly.
    Have played with dvd and tv menu options but no change.
    Any ideas most welcome
    Andy
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Sorry to diss your scart lead - but that's more than likely the problem.
    I had the same problem myself and I had to replace the lead myself because for some reason everything that should be white was showing up pink.
    I think if you set the picture output on the DVD to Composite it should right itself.
    But still, you need to replace the cable. I'd recommend a Philex Thor.
  3. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Is it bright pink (like fuscia)? If so, I suspect you're getting no blue. Try fiddling with the connection at either end.
    D.
  4. sideshowbob
    sideshowbob
    Thanks guys,
    and you were right, it was the cable.
    Put a cheap and nasty scart in and voila - no problems.
    Typical eh - spend loads on a 'decent' cable to find it only lasts
    about a year.
    Well off down the shops again :-(
    Andy.
