It's a long shot, but... Kef Eggs? (And other advice?)
Discussion in 'Home Cinema Speakers' started by Howard0000, Apr 27, 2005.
  1. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    We are considering "down"grading our lounge system from a hifi system (Arcam pre/power amp, Linn speakers and a Squeezebox) and seperate surround system (JBL satellites and Sherwood amp) to something that does evreything in one "package"... We're thinking a decent set of satellites coupled with a "musical" receiver (Something from Denon or Marantz I'm thinking).
    Now the problem is we can't decide onthe satellites.
    We're leaning strongly towards Kef Eggs... But we can't get a demo easily from anywhere and the nearest Superfi (The only place I can find that sells five individual Eggs; we don't need a subwoofer) is in Camden.
    So what can anyone recommend in terms of decent satellites? Are the Keggs competent with music or are there other alternatives? Obviously they'll be used for HC as well but not as often.
    Also...
    Would some kind soul be prepared to lend us a pair of Eggs so we could evaluate their stereo performance and hear them first hand? That would be excellent but it doens't seem very likely unless someone is feeling extra trusting :suicide:
    Cheers for any advice. Apologies if that all sounds rather dis-jointed!
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Check the Canton threads. Much better than the eggses.
  3. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    The CD 10 and CD 50 satellites?
    Are you sure?
  4. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    In terms of price vs performance yes, very similar audio performance for a third the cost (for a CD1 set)!
    Even better audio with fullsize CD50s and CD100s...for "Fullsize" they're also very unobtrusive speakers.
  5. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    Cost isn't an issue. Which would yield better musical performance? Kef Eggs or CD 10s?
  6. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    After hearing music through your own setup, you'll be bleak at the lack of midrange from either of the other two. :thumbsdow
    I'd stick with the B2's and make an effort to consolidate your other equipment.
  7. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    It's not my system :) It's my father's downstairs system which consists of Arcam pre/power amps and Linn speakers.
    I love my system. It's just the way I want it now :D
    I know it'll be a downgrade ,that's why we're after the best satellite speakers available (within reason) really. For music anyway. They'll be used for TV and movies but any set of half decent satellites can do that well enough. Music is important :)
  8. SKA.face
    SKA.face
    I had a similar idea of a basic AV set for a bit of music aswell,away from my main syatem.Big mistake,waste of money,agree with nobber,I used the KEFs,not that good at all,well over hyped,just use two for surrounds,they just not worth the time,for music,forget it.
  9. dazed&confused
    dazed&confused
    Mar 12, 2005
    619
    Kettering, Northants
    +40
    After a taking quite a while getting the set up right, I now find my Castle Compact speakers to be quite adequate for music given their size.
  10. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Howard,
    The Anthony Gallos will knock spots off the suggestions that have been offered so far, if budget really isn't too much of an issue look at the A'Divas with a really good sub. Got them here with a big Velodyne and still can't believe how good the sound is. Not cheap, some don't like the looks, but they do the business.
  11. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Piers,
    Would 5 Gallo Micros with the TR-1 sub still be better than the Eggs?
  12. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    In my opinion yes, though I would demo the TR-1 and a Velodyne.
  13. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    Save some money and buy some boston micro's, much better than the eggs imho.
  14. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    Blimey... Conflicting advice! Lol.
    No one fancies lending me a pair of Eggs so we can try them ourselves if we pay postage both ways? :p
  15. GlennC
    GlennC
    Sep 25, 2002
    1,036
    Poole
    +46
    Howard
    Your more than welcome to try the Elac cinema 3 at home if you pay the postage.
    Glenn
  16. Howard0000
    Howard0000
    Jan 11, 2003
    1,056
    48
    Surrey
    +82
    I wouldn't want to borrow five of them. Just two for now. To assess stereo performance. I'll talk to my father about it tomorrow :) Thanks for the offer. Again I'll let you know :)
  17. Gorecon
    Gorecon
    Have to agree totally with this comment. Went through the same situation. I desperatley wanted a satellite system that could play good stereo music.
    Whilst they are average at best for music you will never beat a proper set of hi-fi speakers for stereo play back.
    Bought some Sonus Faber Concertinos and the difference was staggering.
    I strongly recommend not going with any satellite system if muscial play back is important. I am afraid if you do (or your father) will be sorely disappointed. :(
  18. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    After reading your post properly, i take back the boston micro's.
    If music is your priority and you want sat speakers, you will need a good quality fast musical sub and it can be difficult to integrate.
    Better off to go with a small pair of pmc's (their centre speaker is pretty small too.)
