Itouch wont charge
Discussion in 'Headphones, Earphones & Portable Music' started by johnny monk, Jan 23, 2008.
Tags:
  1. johnny monk
    johnny monk
    Jan 18, 2008
    185
    +65
    Only had ipod touch since xmas now it wont charge through usb lead but it connects and opens itunes so what could be wrong?
  2. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    Could be faulty cable - maybe data lines are intact but +5v line is broken. Also worth taking a close look at the dock connector - I saw one recently where the connection pad had peeled off the board and bent back inside the connector. That was on a 5G iPod but same problem - wouldn't charge.
    regards
    Brian
  3. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    i couldnt say for definite its not the ipod and not the lead but i bought a cheap lead for my itouch and it did the same, mustve been broken so i replaced it with a better lead and it just worked.
  4. johnny monk
    johnny monk
    Jan 18, 2008
    185
    +65
    Ive tried another lead which i know charges another ipod sound but not mine.Tried both through my laptop,could their be something wrong with that?
  5. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    You may have let it get too flat. The only way to charge it back up is with a AC adaptor.
    I have had this with my ipod video. Do you have/can you try an adaptor??
    Pablo
  6. martin@wolfy
    [email protected]
    Apr 30, 2002
    242
    +13
    Have you confirmed the usb port has full voltage i.e 5v? I have read on various forums that the touch is touchy (ha ha) on the voltage. I had problems in getting mine to connect/charge full stop on my built in usb 2 ports. I purchased a usb2 pci card and now all works fine.
    I think from memory the available voltage is shown in the windows device manger under usb .
    Wolfy!!!!
  7. lasty82
    lasty82
    Nov 25, 2005
    234
    Ipswich
    Hello i am having this problem it has worked fine but now it wont charge at all,
    i have connected it to my pc via usb wont charge, used a mains ac adaptor was for ipod video, also my docking station and it wont charge at all.
    If anyone can help me it would be much appreciated thanks
