Italian TVs!
Discussion in 'TVs' started by jamez, May 10, 2003.
  1. jamez
    jamez
    Couple of nice girls have moved in upstairs (1 Italian, 1 English) and have brought with them their television from Italy (can't remember off hand what make or model but it looks pretty basic). They've plugged it in with an adapter, but unfortunately although the picture is fine, the sound is just a constant buzzing.
    Now I realise they wire things up a bit differently over in Italy but has anyone got any ideas on whether I can easily fix their TV for them and get a few brownie points at the same time?!
    All help will be much appreciated. ;)
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    In the UK we use PAL-I, in Italy, PAL-G and PAL-B... although the picture is encoded in the same way the sound carrier is different (5.5MHz vs. 6.0MHz). Unless the TV has a menu (or service menu) that allows you to change to "Unkited Kingdom" or PAL-I, I'm afraid the "nice girls" will have to buy another TV ;)
  3. jamez
    jamez
    Thanks for clearing that up. Guess now I'll have to think of another way to earn those brownie points! At least I can stop them wasting their money on the dodgy TV repair shop down the road!
  4. mjn
    mjn
    May 24, 2001
    18,373
    Herts, England
    +5,460
    u need a UHF <-> VHF convertor, about £50....
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,067
    If the said TV has a SCART or other AV Line inputs on it, it may be cheaper to source a cheap, possibly used, VCR, to use as a tuner.
  6. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    How will this help fix the sound carrier issue? It appears the TV already has a UHF tuner as pictures can be seen.
    nigel's VCR idea would work a treat.
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,126
    Manchester
    +714
    The VCR would work.
    Other solution would be a $ky Digibox + FTV (Free To View) card as this will get all the terrestrial channels but via Astra satellite
    at 28 degrees (+ BBC News 24 & 5 or 6 other useful channels).
    Connect digibox to TV via SCART input.
    A Freeview set-top box would also work.
    Chris Muriel, Manchester.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    A cheap VCR is the best bet! as long as they have some sort of AV input. RS do some very cheap ones start at £40 i think and so do dixons refurb Matsui/Grundig for £50 ish
